Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2007 7724353hydralic 00000049568
Hydraulic cylinders
Dec. 19, 2007
Hydraulic cylinders CDT1 and CDT4 NFPA tie-rod cylinders are available with fluorocarbon, NBR, PTFE, and wear-resistant polyurethane sealing systems. CDT4 operates at pressures to 3000 psi and CDT1 to 1500 psi. Reduced guide clearance ...
Hydraulic cylinders
CDT1 and CDT4 NFPA tie-rod cylinders are available with fluorocarbon, NBR, PTFE, and wear-resistant polyurethane sealing systems. CDT4 operates at pressures to 3000 psi and CDT1 to 1500 psi. Reduced guide clearance provides uniform load distribution; spiral groove in rod bearing lubricates and compensates for pressure change. CDT1 features piston rod diameters from to 5 in.; CDT4 ranges from to 5 in. Bores range from 1 to 8 in.; strokes are available to 120 in.
Bosch Rexroth Corp., (610) 694-8298, www.boschrexroth-us.com
