Pneumatic actuators
Oct. 13, 2011
Airpel Plus low-friction air actuators control ultra-precise movements, including high speeds and extremely short travel distances. Inert qualities and tight tolerances of borosilicate glass and graphite materials smoothly move, hold, or ...
Airpel Plus low-friction air actuators control ultra-precise movements, including high speeds and extremely short travel distances. Inert qualities and tight tolerances of borosilicate glass and graphite materials smoothly move, hold, or press accurately and with high repeatability.
They feature the same piston configuration as the frictionless Airpel-AB Air Bearing Actuators. Maximum friction levels are about 0.5% of load. They operate in temperatures from –55° to 150°C. Bore diameter choices of 9, 16, 24 and 32 mm are offered.
Airpot Corp.
(203) 846-2021
http://bit.ly/HP1011Airpot
