Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 08 01 2010 86150airhydraul 00000058774
Air/hydraulic actuators
Aug. 10, 2010
Air/hydraulic actuators combine a fluid actuator and an air chamber to provide speed of air operation with control and high force of hydraulics. Air chamber converts low air pressure to high hydraulic pressure.
Air/hydraulic actuators combine a fluid actuator and an air chamber to provide speed of air operation with control and high force of hydraulics. Air chamber converts low air pressure to high hydraulic pressure. Three types are available: master cylinder, stem seal master cylinder with integral reservoir and straight bore actuator for use with a remote reservoir. Air chamber sizes are available from 12 to 36 in.2 and hydraulic displacement from 1.0 to 5.9 in.3 They convert 100 psi air pressure to hydraulic pressure rated up to 2045 psi.
MICO Inc.
(507) 625-6426
www.mico.com
