Price Engineering recently expanded its repair, rebuild, retail, and field service operations, with the opening of a 15,000-ft2 addition at its headquarters in Hartland, Wis. The new addition will also serve as the central location for Price On-Site, which provides in-plant and remote field services within Wisconsin and the U.S.
The expansion also allows Price Engineering to offer expanded capabilities in cylinder repair, pump, motor, valve, gearbox, and hydraulic system repairs. A variety of machine tools, test equipment and welding equipment allow the company to service a wide variety of hydraulic system components. In addition, four 1/2-ton Jib cranes and a 15-ton bridge crane allow it to tackle small- to large-scale projects.
The Hartland addition is home to the soon-to-open Hartland Price Hose Center, an authorized Eaton Aeroquip express hose store that specializes in the sale of fluid conveyance components and on-demand, custom hose assemblies. Extended capabilities include, but are not limited to:
Hydraulic Cylinder Repair
Hydraulic System Testing
- Valve test bench and multiple pump test stands
- Mobile HPU test stands
- A 500-gal test reservoir with recirculation loops, pilot pressure, a transfer system and a particle counter
- Various other test equipment, including particle counters, flow meters, data acquisition, test HPU, a 10,000-series CharLynn test bench, and more.
This expansion comes just a few months after the company opened its first hose retail location in Oak Creek, Wis. The store is an authorized Eaton | Aeroquip Hose Center and carries products from Aeroquip, Char-Lynn, Boston and Vickers divisions of the company.
Hoses are available to order and are cut, crimped and packaged to exact specifications. The store stocks thousands of hydraulic and pneumatic items, including fittings, adapters, quick-disconnects, brass products, filters, breathers, flow meters, test points, tube kits, directional control valves, and more.
Other services include proactive on-site maintenance, express hose service and 24/7 emergency service.
Visit www.priceeng.com for more details.
