Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 18231actuator01 00000010333
Long-life actuators
June 5, 2006
Airomatic polyactuators lift loads to 100 lb with 1/2 in. stroke at 50 psig. They have been tested for 5 million cycles without failure or degradation. Compact actuators are constructed of two-pieces of polyurethane welded together for a tight seal. ...
Airomatic polyactuators lift loads to 100 lb with ½ in. stroke at 50 psig. They have been tested for 5 million cycles without failure or degradation. Compact actuators are constructed of two-pieces of polyurethane welded together for a tight seal.
Firestone Industrial Products, (800) 888-0650, www.fsip.com/airomatic
