Increase return flow from cylinders
March 10, 2011
A PO check valve provides a second flow path to speed up retraction of cylinders having a large OD rod. Large-bore cylinders, with relatively large rods for handling large compressive loads, frequently are hampered by inadequate conductor or ...
Large-bore cylinders, with relatively large rods for handling large compressive loads, frequently are hampered by inadequate conductor or line capacity to exhaust oil rapidly from the cylinder during retraction. For example, to move a 10,000-lb tool head, a 6-in.-diameter cylinder with a 5 1/2-in. diameter rod would give adequate performance without threat of buckling the rod.
Assume a pump flow of 25 gpm. During extension, the lines and directional valve handle that flow easily. However, during retraction, the same pump flow to the rod end multiplies flow to 150 gpm from the cap end of the cylinders (with a piston-to-annular area ratio of 6:1).
Balanced flow during retraction can be achieved with the circuit shown here. When the appropriate pressure (several hundred psi) is applied to the rod end, this pressure opens sequence valve C and feeds pressurized pilot oil into pilot-operated check valve B. Valve B, which has a large flow capacity, opens to provide a second path for returning oil directly to tank, in addition to the flow path through directional valve A. The resulting second-path flow through check valve B increases return oil flow three 3 to five times, and with low pressure loss.
Sequence valve C is set at a high enough opening pressure so that minor backpressure during extension does not inadvertently open check valve B.
This circuit design permits directional valve A to be sized according to the pump flow rather than the much larger volume of return flow during retraction. For the cylinder first described, pilot-operated check valve B may draw more than 100 gpm out of the circuit during retraction.
This circuit was submitted by Lew Tomer, of Fluid Controls Inc., Mentor, Ohio, and was originally published in the January 1984 issue of Hydraulics & Pneumatics.
Seals for Hydraulic Cylinders
Dec. 19, 2019
Pressure has been mounting to design and produce cylinders that offer superior sealing performance for enhanced reliability. This article provides an overview of hydraulic cylinders...
Telescoping cylinders go the extra distance (.PDF Download)
Feb. 2, 2016
The great advantage telescopic cylinders have over any other type of cylinders is their ability to provide an exceptionally long stroke from a compact initial package. The collapsed...
