Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2005 12855 Ideas Apps0 00000006048
New hybrid actuator finds application in industry
Dec. 28, 2005
Standard Hy-P hybrid actuator with optional magnetic sensor for position feedback. Hy-P actuator uses pneumatics for power and self-contained hydraulics for control. Since its introduction, the hydropneumatic (Hy-P) ...
Since its introduction, the hydropneumatic (Hy-P) hybrid actuator has undergone continued development and application. As we reported in our June 2004 issue, Hy-P actuators were installed in press used for manufacturing coil assemblies at FEMA Corp., Kalamazoo, Mich. Now, the Fluid Sciences Div. of Perkin-Elmer Co., Beltsville, Md., is using the Hy-P actuators, which are manufactured by RB Hybrodynamics-Inc., Mukilteo, Wash.
Hy-P actuators are pneumatically powered linear actuators or rotary motors with self-contained passive hydraulic dampening, which produces smooth, chatter-free motion with controllable stops. Actuators consist of a pneumatic cylinder and a self-contained hydraulic damping cylinder with its chambers connected through a fluid flow governor (fixed or variable orifice). This allows controlling speed and position hydraulically, with power provided by compressed air.
Although standard off-the-shelf air valves provide sufficient control for Hy-P actuators, custom-designed components manufactured by RB Hybrodynamics allow taking full advantage of actuators' unique characteristics. Developers explain that the novelty of the hydropneumatic actuator is that the absolute value of the volumetric change of the front hydraulic chamber equals the absolute value of volumetric change of the rear hydraulic chamber.
Basic control of motion and positioning of Hy-P actuators involves standard off-the-shelf air valves. However, developers claim that precise motion control can occur at a level, equal to what is currently achievable with electric servo-actuation. At the same time, the power density of Hy-P actuators is said to be six to seven times that of conventional servoactuators.
Latest application
In April of 2005 RB Hybrodynamics completed development of a 6-in. bore linear actuator with a failsafe hydraulic lock that will hold a static load — the Series LLK. These actuators are the largest produced so far, but they actuators are not limited to this size.
The actuators were developed for the Fluid Sciences Div. of Perkin-Elmer Co., which specializes in aerospace and energy technologies, fluid testing, and providing components and subassembly integration processing services to semiconductor manufacturers. Perkin-Elmer technicians retrofitted their existing test equipment that provides and maintains a specified amount of test load in a predetermined position.
Even thought the application required generating several tons of force, conventional hydraulics was deemed unacceptable for the application. However, electromechanical servoactuators would not be able to transmit enough power within size, weight, and price constraints.
LLK actuators have been installed and currently are undergoing testing at Perkin-Elmer facilities. This testing will continue throughout the period of active service without maintenance. RB Hybrodynamics is monitoring the performance of these units by collecting feedback information from the field and using it for optimization and improvements of existing models and to drive future development.
From simple to sophisticated
The basic Hy-P hybrid actuator, Series LO, is intended primarily for simple applications such as presses and pneumatically powered feeding devices. It is said to be capable of providing adjustable speed and accurate positioning in applications where locking in position is not needed.
LO units come with any of three factory-set damping rates for specific speed ranges at 100 psi supply pressure and zero load: 0.1 4 in./sec, 3 7 in./sec, and 6 12 in./sec. Velocity can also or instead be adjusted using conventional pneumatic controls, such as needle valves to meter incoming flow, exhaust flow or both, or via pressure regulators. Standard bore sizes for all types range from 11/8 to 6 in.
This information was provided by Mark Y. Shteynberg, engineering consultant. For more information, visit www.rbhybro.com, or e-mail [email protected]
