HCT-3000 hydraulic cylinder tester assures repaired cylinders are free of rod or piston seal leaks and that they will function properly when reinstalled. It records pressures to 3000 psi. Plumbing is easy with ...
HCT-3000 hydraulic cylinder tester assures repaired cylinders are free of rod or piston seal leaks and that they will function properly when reinstalled. It records pressures to 3000 psi (207 bar). Plumbing is easy with female quick connects for hose termination, while male quick disconnect nipples are provided that terminate in female ¾-in. SAE and ¾-in. pipe threads. It includes up to a 60-gal a reservoir and 21 gpm remote-controlled, pressure-compensated pump.
