Push-connect fittings feature O-rings for leak-tight sealing and stainlesssteel construction for flows of 0.200 Cv. Currently designed to fit 1/4-in. OD tubing, will also be available for 1/8 in., and 4 and 6 mm tubing in in-line, elbow, tee, ...
Push-connect fittings feature O-rings for leak-tight sealing and stainlesssteel construction for flows of 0.200 Cv. Currently designed to fit 1/4-in. OD tubing, will also be available for 1/8 in., and 4 and 6 mm tubing in in-line, elbow, tee, and automatic shut-off versions.
