Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 10 01 2010 86396 Quickcoupl 00000059061
Quick couplings
Oct. 13, 2010
WALklick Quick Fit hydraulic couplings from Walther Prazision with crimp-on hoses save production assembly time and costs by replacing conventional screw connections. They are designed for compact hydraulics, for hose diameters to 1/2 in. (depending ...
WALklick Quick Fit hydraulic couplings from Walther Prazision with crimp-on hoses save production assembly time and costs by replacing conventional screw connections. They are designed for compact hydraulics, for hose diameters to 1/2 in. (depending on the end connection), and working pressures to 4000 psi. They can be installed without any tools and little space, simply by clicking them on. Shut-off valves prevent leakage during connection process, making it unnecessary to vent the hydraulic system. They are available in brass, along with a through type (non-valved) version.
Spez-Tech Engineered Fluid Power Technology, (905) 828-5579, www.speztech.com
