Hose and couplings
Aug. 10, 2007
Teflon hose features reinforced stainless steel braid with white extruded inner tube. It withstands temperatures from –65° to 450°F, and resists corrosive fluids and vibration. It is available in diameters from 3∕16- to 1-in. ID and 0.312- to ...
Teflon hose features reinforced stainless steel braid with white extruded inner tube. It withstands temperatures from –65° to 450°F, and resists corrosive fluids and vibration. It is available in diameters from 3∕16- to 1-in. ID and 0.312- to 1.135-in. OD. It is rated for pressure to 3000 psi with minimum burst pressure to 12,000 psi. Skiving is not required. Nine different couplings are available including JIC female 45° swivel in 21 different sizes, 90° and 45° tube swivel styles, and Oface seal versions.
Kurt Hydraulics, (866) 257-7995, www.kurthydraulics.com
