Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 08 01 2010 86145banjofitti 00000058766
Banjo fitting
Aug. 10, 2010
Zero-Leak Gold custom-designed banjo fitting product line is made with multiple seal technology for a zero-leak connection in vibration, pressure spike and temperature variation applications. Separate metal-to-metal and ...
Zero-Leak Gold custom-designed banjo fitting product line is made with multiple seal technology for a zero-leak connection in vibration, pressure spike and temperature variation applications. Separate metal-to-metal and elastomeric seals protect against leaks while geometry and system pressure ensure positive sealing. Bolt and body are held in place by O-rings, which eliminate need for copper washers and similar devices. Design can be adapted to steel, stainless steel, aluminum, and other materials. They fit sizes that accept SAE J1126 and ISO 6149 port configuration.
EPCO Products Inc., (260) 747-8888
www.zero.com
