Zero-Leak Banjo Fittings
Sept. 4, 2015
Custom-designed banjo fitting product line is made with multiple seal technology for a zero-leak connection in vibration, pressure spike and temperature variation applications. Multiple seals distinguish the Zero-Leak Gold Banjo Fitting from traditional copper washer dependent Banjo fittings. Two separate and independent seals form a double redundant sealing system.
Custom-designed banjo fitting product line is made with multiple seal technology for a zero-leak connection in vibration, pressure spike and temperature variation applications. Multiple seals distinguish the Zero-Leak Gold Banjo Fitting from traditional copper washer dependent Banjo fittings. Two separate and independent seals form a double redundant sealing system. A primary metal-to-metal seal works in conjunction with an elastomeric backup seal to create a zero-leak connection.  Banjo bolt and body are held in place by the O-rings, in addition to their backup seal function. Design can be adapted to steel, stainless steel, and aluminum. They fit sizes that accept SAE J1926 and ISO 6149 port configurations.  Zero-Leak Gold Banjo Fittings offer a zero-leak guarantee.
EPCO Products Inc., (800) 879-3726
www.zeroleak.com
Electro-Pneumatic Pressure Regulator Provides High Level of Accuracy
April 18, 2024
Inclusion of electronic controls in the Proportion-Air QBX electro-pneumatic pressure regulator ensures accurate and repeatable pressure control.
Pressure Rating Hydraulic Components
Feb. 2, 2015
Fatigue pressure ratings are an important element of product design and lifecycle management in fluid-power systems.
