311441080 © Scharfsinn86 | Dreamstime.com
Regenerative braking offers many performance advantages for electric-powered machines
Achieve the Benefits of Regenerative Braking by Optimizing Motor Controllers
March 19, 2025
Optimizing the motor controllers used with regenerative braking systems improves efficiency, range and performance for electric machinery.
Regenerative braking systems hold transformative potential for electrified machinery, with studies indicating they can enhance energy efficiency by up to 60.1%.
With industries increasingly focused on energy conservation and emissions reduction, the impact of leveraging kinetic energy to recharge batteries cannot be understated. Authoritative voices in the space, such as the International Energy Agency (IEA), cite energy efficiency as the “first fuel” in clean energy transitions, indicating that the foremost defenses in carbon dioxide (CO2) mitigation lie in technologies like regenerative braking.
Motor controllers are central to these systems. They are the “brain” responsible for managing power flow, ensuring effective energy recovery, and maintaining safe braking. By optimizing these motor controllers, OEMs unlock enhanced range, improved efficiency, and greater operational capabilities in the next generation of electrified machinery.
What is Regenerative Braking?
Traditional friction-based braking dissipates kinetic energy as heat, an irretrievable loss. Regenerative braking, however, captures and repurposes this kinetic energy into electrical energy, storing it in the vehicle’s battery for future use.
But while the basic theory of regenerative braking is simple, the mechanics (and benefits) behind this transformation hinge on a complex series of component integrations.
Understanding the Role of Key Components
With a regenerative braking system, the electric motor serves a dual purpose: It acts as a propulsion unit and generator during acceleration and deceleration, respectively. The ultimate effectiveness of such a system relies on the distinct yet interconnected components that comprise it:
Benefits of Regenerative Braking Systems
The advantages of regenerative braking extend far beyond the vehicle’s immediate function. These benefits can be divided into three distinct categories according to their impacts on sustainability, costs, and overall efficiency.
1. Environmental Advantages
By capturing and converting kinetic energy into usable electrical power, regenerative braking systems reduce reliance on external energy sources. This decreased demand directly correlates with lower emissions, aligning with global sustainability goals. It also addresses one of the primary concerns with electric vehicles (EV): limited range. By extending this range and improving overall efficiency, regenerative braking serves as a critical enabler in the transition to electrified machinery.
2. Economic Benefits
The financial incentives of regenerative braking compound when scaled across industrial applications. Enhanced energy efficiency translates to reduced operational costs, both from decreased fuel consumption and by reducing the mechanical wear on brakes or other components. The latter both minimizes maintenance and extends the lifespan of key vehicle systems, providing a compelling return on investment for OEMs and fleet managers alike.
3. Operational Gains
EVs outfitted with regenerative braking systems deliver more value per mile by extending the vehicle’s range, reducing downtime required for recharging or refueling. This improvement proves particularly valuable in stop-and-go conditions, such as warehouse logistics, as it captures incremental energy that can lead to measurable productivity gains over time.
Read "The Rising Influence of Sustainability on Hydraulics and Pneumatics" to learn more about the impact sustainability is having on the fluid power industry.
Optimizing Regenerative Braking Systems
Most regenerative braking systems abide by the “rule method,” a binary approach that determines how much braking to apply based on predefined “if/then” logic. While straightforward, this method lacks the flexibility to adapt to the complexities of real-world scenarios.
Building on these design principles, modern designs leverage innovative techniques to optimize performance. Consider two examples: GA-RBD and Fuzzy Control Strategies.
GA-RBD: Targeted Efficiency for Predictable Applications
Genetic algorithm-based, energy recovery-dominated regenerative braking torque distribution (GA-RBD) strategies demonstrate marked efficiency improvements over traditional rule-based methods, including:
  • +22.8% greater energy recovery
  • +4.8% enhanced braking stability
  • performance gains that scale proportionally with higher speeds and braking intensity.
GA-RBD algorithms are meticulously fine-tuned through simulated scenarios, ensuring optimal energy recovery and braking stability under defined conditions. Such precision makes these systems ideal for autonomous guided vehicle (AGV) and autonomous mobile robot (AMR) applications, where operating environments and duty cycles are controlled and calculable.
Current developments suggest GA-RBD strategies will likely see their first implementation in dual-motor configurations for on-road electric vehicles, paving the way for broader adoption.
Fuzzy Control Strategies: Adapting to Dynamic Environments
In contrast to the simulation-centric GA-RBD approach, fuzzy control strategies adopt a more adaptive, non-linear methodology. These systems dynamically adjust braking parameters in real-time, tailoring energy recovery and braking performance to actual driving conditions and variables such as:
  • vehicle speed
  • braking intensity
  • state-of-charge
  • percentage of electric braking.
This flexibility makes fuzzy logic ideal for less “scripted” industrial settings, such as mobile elevated work platforms and similar, manually operated machinery. Overall, leveraging fuzzy control strategies achieves between 13% and 30% improved energy efficiency compared to rule-based methods.
Challenges of Regenerative Braking Systems
The efficiency gains of regenerative braking systems are well-documented — under ideal laboratory conditions. Translating these benefits into real-world applications presents challenges that must be addressed to ensure optimal performance and safety.
Energy Storage Constraints
A common issue arises when the vehicle’s battery is near full capacity during heavy braking. In such cases, excess energy recovered by the system cannot be stored, leading to inefficiencies or even system stress.
Potential solutions include utilizing an energy buffering system that functions like another battery in temporarily holding and redistributing excess energy to auxiliary systems. Alternatively, implementing charging cutoffs can ensure batteries maintain sufficient headroom for energy absorption, preventing overcharging incidents.
Braking Safety and Stability
Maximizing energy recovery through advanced algorithms must not come at the expense of braking stability. Poorly managed torque distribution can result in uneven braking forces, creating safety risks such as vehicle instability or loss of control.
To address this, regenerative braking systems should be complemented by traditional safety measures. This includes anti-lock braking systems (ABS) to prevent wheel lock-up during deceleration, and traction control systems that ensure proper distribution of braking force to maintain vehicle stability.
Read "Why Steering and Drive Systems are Transitioning to By-Wire Technology" to learn how electrification, automation and other industry trends are influencing steering and drive technology.
Design Challenges
For OEMs, another pertinent challenge lies in logistics. Many advanced regenerative braking systems rely on dual-motor configurations that effectively double the machine’s weight, space, and cost — factors already at a premium in industrial applications.
In these cases, the only choice is mitigation.
OEMs may need to choose: Do they opt for a single-motor design that sacrifices a measure of performance, or do they design and develop around the power (and hardware burden) of a dual-motor? For single-motor designs, integrating robust BMS and advanced charging solutions can improve energy recovery and efficiency, potentially offsetting performance limitations.
In any case, technical expertise, strategic partnerships, and industry-tailored solutions will be critical to overcoming these obstacles effectively.
Policies Driving Regenerative Braking Adoption
Global policy initiatives promise to greatly accelerate the adoption of regenerative braking systems, creating an environment ripe for innovation and industry. For example, according to the IEA:
  • Governments worldwide allocated incentives totaling $170 billion to domestic manufacturers of clean technologies, with a significant portion directed toward EV development.
  • Over 5,000 clean energy policies remain active across more than 50 countries, creating a favorable framework for development teams to expand their pursuits.
  • Since 2020, global investments in clean energy have approached $2 trillion, with 80% of these funds concentrated in China, the European Union (EU), and the United States.
These figures underscore the unique opportunities available to OEMs, particularly those in regions leading these efforts. Manufacturers can position themselves at the forefront of the electrification revolution by leveraging both financial inflows and favorable policy landscapes.
To illustrate, consider the noteworthy example of the EU’s Net-Zero Industry Act.
In effect since June 29, 2024, this policy aims to bolster manufacturing capacity for clean energy technologies across the EU. By streamlining permitting processes, improving access to public funding, and prioritizing infrastructure development, the act equips European OEMs with the resources necessary to drive advancements in critical technologies like regenerative braking.
Incentivizing policies like this are crucial in light of supply chain fragility, particularly regarding batteries. This further supports, albeit indirectly, the immense value of regenerative braking and battery management systems. Simply put, these technologies enhance battery longevity — thereby increasing supply chain resilience while maximizing investment value.
Optimizing Motor Controllers: A Sustainable, Strategic Imperative
Efficiency is rightly viewed as the first line of defense in mitigating emissions, and regenerative braking stands as a testament to this principle. Motor controllers are the core of this technology, reshaping the boundaries of efficiency with advanced algorithms and application-specific designs.
While logistical challenges remain, innovative solutions continually emerge to address them, bolstered by substantial investments anchored in government policy.
As the global transition to electrification gains momentum, advancements like regenerative braking are more than just new technology. They are a strategic cornerstone in building a sustainable, all-electric future.
Choosing the right partners in their electrification journey empowers OEMs to lead this evolution, driving innovative solutions that will shape the future of electric mobility.
This article was written and contributed by Zachary Penrod and Matthew Koehler of Inmotion Technologies, a ZAPI GROUP company.
Zachary Penrod | Key Accounts and Marketing Manager at Inmotion
Zachary Penrod is the Key Accounts and Marketing Manager at Inmotion, a ZAPI GROUP company. In his role, he oversees key customer relationships and drives strategic marketing and business development initiatives to strengthen Inmotion’s position in the electrification industry. With a background in engineering and sales, Penrod combines technical expertise and market insight to deliver tailored solutions that meet evolving customer needs. Penrod holds a Bachelor of Science in mechanical engineering from Penn State University and Master of Business Administration from University of Pittsburgh Katz Graduate School of Business.
Matthew Koehler | Engineering Manager at Inmotion
Matthew Koehler is an Engineering Manager with a focus on R&D and Applications at Inmotion, a ZAPI GROUP company. Koehler builds and maintains strong customer relationships to drive business growth. He has over 10 years of experience in engineering and motion control technologies, bringing a deep understanding of electrification solutions to Inmotion and its partners and customers. Koehler collaborates closely with clients to identify their needs and deliver innovative, tailored solutions that support their long-term success. Koehler received a Bachelor of Science in mechanical engineering from Virginia Tech.
Andreas Mair of GKN Automotive explores some of the latest developments in electric motor technology and their role as the industry transitions to electric vehicles.
April 1, 2024
Phoenix Contact’s Ted Thayer and MxD’s Eric Kozikowski explore the efficiency, connectivity and technical intricacies of digital programmable logic controllers.
