Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 05 01 2008 80342lockingbus 00000052798
Locking Bushings
May 14, 2008
ETP Express shaft locking bushings provide precise connection between keyless shafts and mounted components. Low total indicated runout of less than 0.0008 in. minimizes component runout on rotating shafts, reducing machine vibration and noise. ...
ETP Express shaft locking bushings provide precise connection between keyless shafts and mounted components. Low total indicated runout of less than 0.0008 in. minimizes component runout on rotating shafts, reducing machine vibration and noise. They are designed with a doublewalled hardened steel sleeve and flange filled with a pressure medium to handle torque ranges from 39 to 12,538 lb-ft. Sizes range from 58 to 2 in. or 15 to 80 mm.
Zero-Max Inc., (800) 533-1731, www.zero-max.com
