Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 11 01 2007 76365twoearpng 00000048963
Two-ear style clamp
Nov. 21, 2007
Clamp installs easily with crimping pliers by placing clamp over tubing, pushing tube into fitting, sliding clamp into position, and crimping ears to secure. It is available in zincplated steel or 304 stainless steel, and can be used with ...
Clamp installs easily with crimping pliers by placing clamp over tubing, pushing tube into fitting, sliding clamp into position, and crimping ears to secure. It is available in zincplated steel or 304 stainless steel, and can be used with tubing with 516, … , and to 532 in. ODs. They are 932, …, or 532 in. wide.
Beswick Engineering Co Inc., (800) 354-5014, www.beswick.com
How To Select Hydraulic Connectors For Leak-Free Reliability
June 14, 2016
Hydraulic oil leaks are often considered to be an inherent characteristic of hydraulic machines. While this may have been true 30 years ago, advances in sealing technology and...
