Heat exchangers
March 9, 2010
Mobile MA heat exchangers feature brazed aluminum P-bar plate and bar core technology engineered with an aggressive turbulator that produces high heat transfer for flow rates from 2 to 150 gpm. Rated to 250 psi at ...
Mobile MA heat exchangers feature brazed aluminum P-bar plate and bar core technology engineered with an aggressive turbulator that produces high heat transfer for flow rates from 2 to 150 gpm. Rated to 250 psi at temperatures to 300° F with petroleum- or water-based hydraulic fluid. The lightweight, compact design provides high heat transfer per given envelope while minimizing pressure drop. Comes with SAE ports standard, others optional, 30/60-psi bypass available; custom units also available.
Thermal Transfer Products
(262) 554-8330, www.thermaltrasnfer.com
