Magnetic angle sensors
April 7, 2014
The PRAS26 Series magnetic angle sensors for automated applications offer an absolute output signal over the entire 0 to 360° measurement range. The sensor’s constant wear-free operation is through the use of an external position magnet. The device’s flat housing is made of heat-resistant materials, such as thermoplastic and epoxy glass fiber. Completely encapsulated electronics withstand strong shocks, vibration, and moisture penetration. The sensor is equipped with the analog outputs 0.5 to 4.5 V, 0.5 to 10 V, or 4 to 20 mA.
ASM Sensors Inc., (630) 832-3202
