Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9819pneuprod020 00000003610
Rod lock attachment for air cylinders
July 26, 2005
NuLock Series rod lock product line is designed for safe, reliable load holding during emergency stop conditions when air supply drops in pressure.
NuLock Series rod lock product line is designed for safe, reliable load holding during emergency stop conditions when air supply drops in pressure. Piston-operated clamp mechanically locks a cylinder piston rod in place in the event of an air supply failure. Compatible with seven ISO/VDMA cylinder bore sizes from 32 to 125 mm and six NFPA cylinder bore sizes from 1½ to 5 in.
Numatics Inc.
(248) 887-4111
www.numatics.com
