Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 46100prods0302j 00000021296
Corrosion-resistant shock absorbers
March 20, 2007
Weartec Plus standard corrosion protection is available on industrial shock absorbers and feed controller threaded outer tubes for washdown and outdoor environments. Independent laboratory salt-spray testing shows that its corrosion ...
Weartec Plus standard corrosion protection is available on industrial shock absorbers and feed controller threaded outer tubes for washdown and outdoor environments. Independent laboratory salt-spray testing shows that its corrosion protection is 30% higher than platinum, Armaloy, and nickel plate; 67% higher than hard chrome; and 150% higher than black oxide.
Ace Controls Inc., (800) 521-3320, www.acecontrols.com
Smart Actuation of Pumps and Valves
May 15, 2015
New actuation technology holds promise to do away with the need for pilot circuits for valves in mobile hydraulic systems.
How To Size A Hydraulic Tank
March 24, 2015
The rules of thumb for reservoir size differ for open and closed circuits. For a conventional reservoir used in open circuits the general rule is a tank oil capacity of 3 to 5...
