Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 12 01 2010 86701 Hydraulict 00000059303
Hydraulic testing
Dec. 14, 2010
Flo-Tech PFM tester features an internal burst disk to simultaneously measure flow, pressure and temperature on hydraulic machines. In case of over-pressurization, flow is interrupted. Turbine rotor and magnetic pick-up measure flow rates by ...
Flo-Tech PFM tester features an internal burst disk to simultaneously measure flow, pressure and temperature on hydraulic machines. In case of over-pressurization, flow is interrupted. Turbine rotor and magnetic pick-up measure flow rates by gauging pulse from rotor and transferring signal to LCD or PC. Accuracy is 1% of full scale and repeatable to 0.2%. Temperature is measured with internal and analog or digital pressure sensors.
Racine Flow Meter Group
(262) 639-6770
www.flo-tech.com
