Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2007 67502 Prods10100 00000043616
Hydraulic connector
June 13, 2007
STC EZ-Torque connector is compatible with standard threaded ports and can be installed without using a port adapter. It eliminates the need for special ports and tools and simplifies port connections by allowing direct connection to existing ...
STC EZ-Torque connector is compatible with standard threaded ports and can be installed without using a port adapter. It eliminates the need for special ports and tools and simplifies port connections by allowing direct connection to existing ports. It also reduces hose fitting installation time. A lock-down anti-rotation design feature allows orienting the connection at the proper angle. It comes in five sizes for pressure ratings of 3989, 4279, and 5004 psi.
Eaton Corp., Hydraulics Operations,
(952) 294-7992,
www.hydraulics.eaton.com
