Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2007 67505 Prods10302 00000043618
Magnetic proximity switch
June 13, 2007
The 9M50 magnetic proximity switch fits D-shaped grooves in air cylinders, and can be inserted anywhere along the barrel, rotated, and locked into place. It is fully encapsulated and comes in reed and electronic styles in either NPN or PNP. Reed ...
The 9M50 magnetic proximity switch fits D-shaped grooves in air cylinders, and can be inserted anywhere along the barrel, rotated, and locked into place. It is fully encapsulated and comes in reed and electronic styles in either NPN or PNP. Reed versions are available from 5 to 120 Vac/dc. Normally closed versions also available. Standard wire lengths include 3-m wire leads, or optional 8-mm quick-connectors. Female connector mating cords are available.
Canfield Connector,
(330) 758-8299,
www.canfieldconnector.com
