Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 21826products01 00000011994
Directional spool valve
July 13, 2006
SWL valve bank's load sensing operates multiple hydraulic cylinders and motors simultaneously and independently from each other at different velocities and pressures. It is rated for flows to 30 lpm and operating pressure to 315 bar. ...
SWL valve bank's load sensing operates multiple hydraulic cylinders and motors simultaneously and independently from each other at different velocities and pressures. It is rated for flows to 30 lpm and operating pressure to 315 bar. Electro-proportional control allows smooth movements. Simple ancillary blocks implement over-center valves, piloted check valves, pre-load valves, and shock and suction valves.
Hawe Hydraulics, (704) 509-1599, www.hawehydraulics.com
