Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 02 01 2008 78429oilcoolers 00000051068
Oil Coolers
Feb. 15, 2008
MA/BOL oil coolers handle extreme heat loads and feature brazed aluminum P-BAR plate and bar core technology engineered with an aggressive turbulator for ultra high heat transfer. More than 22 standard industry nominal sizes come with ...
MA/BOL oil coolers handle extreme heat loads and feature brazed aluminum P-BAR plate and bar core technology engineered with an aggressive turbulator for ultra high heat transfer. More than 22 standard industry nominal sizes come with fan, motor, shroud, sensor, and bypass options. Air-side fin minimizes fouling and static pressure. Welded fittings/ports and manifolds ensure structural integrity. They come with standard SAE ports; NPT and BSPP ports available.
Thermal Transfer Products,
(262) 554- 8330,
www.thermasys.com/thermal_transfer
A Word About Specific Heat Of Hydraulic Oil
March 14, 2017
Based on specific heat alone, water appears to be a superior hydraulic fluid to oil. Because it takes twice is much heat, to get the same quantity of water to the same temperature...
How to Select a Mobile Hydraulic Heat Exchanger (.PDF Download)
April 11, 2016
Sizing and selecting a heat exchanger to cool a mobile hydraulic system presents some real challenges. First, you have to come up with an accurate assessment of how much heat ...
