Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles May2004 Pneusys0100png 00000000477
Go with the high flow
May 1, 2004
The A50 Series of compressed air preparation units allows flow rates to 35,000 lpm. The pressure regulator features an electronic pilot control or an integrated pilot valve. The filter-water-separator is equipped with an automatic drain valve and contamin
The A50 Series of compressed air preparation units allows flow rates to 35,000 lpm. The pressure regulator features an electronic pilot control or an integrated pilot valve. The filter-water-separator is equipped with an automatic drain valve and contamination indicator. All components, including the soft start/stop valve (in 2/2 or 3/2-way design), can handle the demands of offshore and explosion-protection areas, as well as blow-molding machines. The series is used as a master unit, but is suitable for supply pressures to 17.5 bar.
Hoerbiger-Origa,
(800) 695-5984,
www.hoerbiger-origa.com
