Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles September2004 Ideas0204png 00000000540
Quick clip connection allows easy measuring of hydraulic systems
Sept. 1, 2004
Cost-efficient products are always desirable in today's economy, but when such a product also claims to get the job done faster, it's certainly worth looking into. The Serv-Clip-1, from IC Fluid Power, Rossford, Ohio, promises both of these benefits to fl
The Serv-Clip-1 offers a quick and inexpensive way to tap into hydraulic pipe or tube for conducting any of several diagnostic procedures: pressure, temperature, flow rate, or for taking fluid samples.
Cross-sectional drawing shows components of Serv-Clip-1 and how they establish an opening in pressurized hydraulic line for subsequent testing.
Cost-efficient products are always desirable in today's economy, but when such a product also claims to get the job done faster, it's certainly worth looking into. The Serv-Clip-1, from IC Fluid Power, Rossford, Ohio, promises both of these benefits to fluid power users.
The Serv-Clip is a pipe measuring connection that connects to a pipe to allow the user to take a variety of hydraulic system measurements: pressure, temperature, rate of flow, or fluid samples for subsequent particle counting. Pipes can be pressurized to 9100 psi and have diameters from 10 mm to 42 mm or 3/8 to 11/2 in., with wall thicknesses up to 3/16-in.
Once the Serv-Clip is placed into position on the cleaned surface of the pressurized hydraulic pipe, a center cylinder is screwed down. Then, a needle is pressed through the wall of the pipe.
Using the principle of plastic deformation, it creates an opening with an approximate diameter of 0.087- in. The cylinder head is then unscrewed, pulling out the needle, and leaving the pierced hole open so measurements can be taken. Once installed, the serv-Clip provides a permanent connection.
The entire connection process can be done without special tools and takes only a few minutes. The system is completely leak proof, thanks to a Viton O-ring designed into the system.
For more information contact IC Fluid Power at (877) 423-5843 or visit www.icfluid.com.
