Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2007 67527 Prod Spot01 00000043635
NFPA cylinders
June 13, 2007
NEN cylinders have a magnetic piston for position sensing, adjustable cushions, low-friction nitrile seals, PTFE wear band on the piston, and sleeve-nut construction with NFPA MS4 bottom-tapped mounting. They come in 11⁄2, 2, 21⁄2, 31⁄4, ...
NEN cylinders have a magnetic piston for position sensing, adjustable cushions, low-friction nitrile seals, PTFE wear band on the piston, and sleeve-nut construction with NFPA MS4 bottom-tapped mounting. They come in 112, 2, 212, 314, and 4 in. bores for operating pressures from 7 to 140 psi. They operate in temperatures from –25° to 140° F or 0° to 400° F with optional Viton seals.
IMI Norgren Inc.,
(303) 794-2611,
www.norgren.com
