Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2007 67517 Prod Spot02 00000043630
Air clamping cylinders
June 13, 2007
Series 900 air clamping cylinders are available in 2-, 3- and 4-in. bores with a 1- or 2-in. stroke. Single-acting cylinders use half the air of double-acting units and exert up to 1900 lb of holding force. They feature cast aluminum bodies with ...
Series 900 air clamping cylinders are available in 2-, 3- and 4-in. bores with a 1- or 2-in. stroke. Single-acting cylinders use half the air of double-acting units and exert up to 1900 lb of holding force. They feature cast aluminum bodies with horizontal and vertical mounting capability, Buna seals with hard chrome plated steel piston rods, and a threaded or plain rod end.
Control Line Equipment Inc.,
(216) 433-7766,
www.control-line.com
