Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9691spotlightfi 00000003477
O-ring seal tube fittings
June 27, 2005
Fitting creates a leak-free seal when the tube is inserted into the body of the fitting. Seals tighter under pressure, reverses its seal under vacuum, and continues to seal at zero pressure as it is capable of returning to its original shape. ...
Fitting creates a leak-free seal when the tube is inserted into the body of the fitting. Seals tighter under pressure, reverses its seal under vacuum, and continues to seal at zero pressure as it is capable of returning to its original shape. Held by a locking tapered nut and split tapered internally serrated ring for tight gripping.
Lenz, (937) 277-9364, www.lenzinc.com
