Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Newprods0400png 00000000380
O-ring alternative
April 3, 2005
Trap-Seal is a trapezoidalshaped O-ring that reduces possibility of popping out of the O-ring face seal groove. Trapezoidal design provides consistently positive retention in the groove and creates a larger overlap between groove lip and seal ...
Trap-Seal is a trapezoidalshaped O-ring that reduces possibility of popping out of the O-ring face seal groove. Trapezoidal design provides consistently positive retention in the groove and creates a larger overlap between groove lip and seal for increased retention. Interchangeable with the standard O-ring used in half-dovetail grooves, making seal replacement in the field quick and easy.
Parker Hannifin Corp., Tube Fittings Div.,
(800) C-PARKER,
www.parker.com/tfd
