Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Pneu0202png 00000003131
Swing arm clamps
June 2, 2005
Two new bore sizes in the Series PB Swing Arm Clamp of 25 and 32 mm. Available in short and long strokes. Uses hardened helical spline and three hardended drive balls. Keyed interface between the rod and arm. Adjustable rear plug. Mounting ...
Two new bore sizes in the Series PB Swing Arm Clamp of 25 and 32 mm. Available in short and long strokes. Uses hardened helical spline and three hardended drive balls. Keyed interface between the rod and arm. Adjustable rear plug. Mounting patterns on two surfaces. Flow controls not required. Two switch grooves on all sides of clamp body.
PHD Inc.,
(260) 747-6151,
www.phdinc.com
