Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Newproduct Products0201png 00000000427
Tees and connectors
April 3, 2005
The Hard Line Series of barbed tees and connectors provide a leak-proof seal on rigid tubing, without the need for tube clamps. The barb has a sharp sealing point that is slightly larger than the fitting's shaft for a tight seal to 200 psi. ...
The Hard Line Series of barbed tees and connectors provide a leak-proof seal on rigid tubing, without the need for tube clamps. The barb has a sharp sealing point that is slightly larger than the fitting's shaft for a tight seal to 200 psi. Stocked in white nylon, natural polypropylene, natural Kynar, and clear polycarbonate. Barb sizes fit tubing IDs of 1/16, 1/8, 5/32, 3/16, and 1/4 in.
Ark-Plas Products Inc.,
(870) 453-2343,
www.ark-plas.com
