Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Newprodsb0201png 00000000391
Positive displacement flow meters
April 3, 2005
HPD Series positive displacement flow meters and batch controllers are designed for high-viscosity, nonabrasive fluid applications. Flow meters maintain consistent accuracy within ±0.5% at low flow rates. Feature stainless-steel gears and ...
HPD Series positive displacement flow meters and batch controllers are designed for high-viscosity, nonabrasive fluid applications. Flow meters maintain consistent accuracy within ±0.5% at low flow rates. Feature stainless-steel gears and bearings, and come in bodies of stainless steel or high-strength aluminum. Available in 1/4, 1/2, and 11/4 in. NPT port sizes for flow ranges from 0.003 to 120 gallons/min. Operate at pressures to 5000 psi and temperatures to 400° F. Two HPD Series batch controllers provide nine programmable batch amounts, batch counter and totalizer, batch error compensator, dual relays for solenoid valve control, and a 4 to 20-mA batch fill indicator.
Hedland Flow Meters,
(800) 433-5263,
www.hedland.com
