Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Newprods0301png 00000000381
Strength and support
April 3, 2005
Piper Power Port adapters have adjustable nut washer O-ring design, giving a robust seal at the port end. Wider nut and more thread length allow higher assembly torque, increased clamp load and holding strength. Design surpasses standard SAE ...
Piper Power Port adapters have adjustable nut washer O-ring design, giving a robust seal at the port end. Wider nut and more thread length allow higher assembly torque, increased clamp load and holding strength. Design surpasses standard SAE fittings in high vibration applications; fittings are the same envelope size and are assembled with standard tools. Fitting and wrench size of the nut are the same as SAE. O-ring is contained in a pocket and can be disassembled and assembled without damage to the mating part. Available for 37° JIC (SAE J-514) adapters and face seal.
Piper Industries Inc.,
(586) 771-5100,
www.piperindustries.com
