Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 03 01 2005 Prod0103png 00000003248
Lift table
March 1, 2005
Pneumatic lift table is a short, stable cylinder that incorporates four guide shafts for maximum rigidity. Designed for lifting applications where other nonrotating cylinders cannot handle an overhung load and space is at a premium. Available in three bor
Pneumatic lift table is a short, stable cylinder that incorporates four guide shafts for maximum rigidity. Designed for lifting applications where other nonrotating cylinders cannot handle an overhung load and space is at a premium. Available in three bore sizes: 50mm, 80mm, and 125mm; can produce 1900 pounds of lifting force at 100 psi. PTFE-impregnated hard anodized body yields low friction, maximum seal life. Options include internal bumpers, magnetic position sensing, high temperature operation. Stroke lengths are available in 5mm increments to 100mm.
Bimba Mfg. Co., (708) 534-8544, www.bimba.com
