Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Newprods0202png 00000000376
Flange adapters
April 3, 2005
Adaflange unified 4-bolt U61 flange adapters have bolt patterns that will mount on SAE Code 61 flange ports. Available 2-bolt adapters have bolt patterns that will mount on either of the two diagonal tapped holes on SAE Code 61 flange ports. ...
Adaflange unified 4-bolt U61 flange adapters have bolt patterns that will mount on SAE Code 61 flange ports. Available 2-bolt adapters have bolt patterns that will mount on either of the two diagonal tapped holes on SAE Code 61 flange ports. They are designed to connect an SAE 4-bolt flanged port to a tube, pipe, or hose. Base footprint is narrower than the minimal pad width of commercially available SAE flanges, enabling closer placement of these adapters on components and applications such as manifolds.
Adaconn + Inserta,
(215) 643-1900,
www.adaconn.com
Oct. 7, 2021
