Piston accumulators
Sept. 15, 2011
EHP line of piston accumulators suit standard and special applications in mobile, wind energy, oil and gas, and industrial market segments. They are available in two size ranges: 1 qt to 2.5 gal with 4-in. bores and 1 to 5 gal with ...
EHP line of piston accumulators suit standard and special applications in mobile, wind energy, oil and gas, and industrial market segments. They are available in two size ranges: 1 qt to 2.5 gal with 4-in. bores and 1 to 5 gal with 5.75-in.bores. They are rated to 3000 psi with a 4:1 safety factor and feature double piston seals for lower gas losses. Threaded end caps, SAE threaded ports, and Nitrile seals are standard. Options include ASME, CE certification; stainless-steel design with pressure ranging up to 10,000 psi; SAE Flange, BSP, NPT ports; piston position indicator; and other seal materials, including Viton, EPR, Butyl etc.
Olaer USA Inc.
(713) 937-8900
http://bit.ly/HP911Olaer
