Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Articles 06 01 2007 67511 Prods10502 00000043624
Relief valves
June 13, 2007
Series 1DR50 is a direct-acting hydraulic pressure relief cartridge valve with pressure ratings of 70, 210, 280, or 350 bar and a maximum flow rate of 50 lpm. Poppet design reduces internal leakage to 0.5 lpm when closed. Seat and poppet design ...
Series 1DR50 is a direct-acting hydraulic pressure relief cartridge valve with pressure ratings of 70, 210, 280, or 350 bar and a maximum flow rate of 50 lpm. Poppet design reduces internal leakage to 0.5 lpm when closed. Seat and poppet design increases contamination tolerance. They can be fitted into standard line bodies or used with other valves in a system with manifold blocks.
Integrated Hydraulics Inc.,
(440) 974-3171,
www.integratedhydraulics.com
