Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 43976 Products02 00000020105
Miniature orifice restrictor
Jan. 2, 2007
The 156 Jet, 0.156 in. diameter, single orifice restrictor uses the same technology as larger sizes. It weighs 0.7 g nominal and is 42% lighter and 12.5% shorter than older versions, which provides a reduced installation boss size and weight. ...
The 156 Jet, 0.156 in. diameter, single orifice restrictor uses the same technology as larger sizes. It weighs 0.7 g nominal and is 42% lighter and 12.5% shorter than older versions, which provides a reduced installation boss size and weight. It is available in 34 standard Lohm rates (3000 to 30,000 Lohms) and is 100% bidirectionally flow tested for accurate performance.
The Lee Co.,
(860) 399-6281,www.theleeco.com
