Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 12718pproducts0 00000005921
Rodless cylinders
Nov. 30, 2005
HORV rodless cylinders are short, thin, and light. Flat piston creates 40% thinner profile. Block-type end cap eliminates need for mounting brackets and reduced zero stroke results in dead stroke that is 35% shorter than band-type cylinders. ...
HORV rodless cylinders are short, thin, and light. Flat piston creates 40% thinner profile. Block-type end cap eliminates need for mounting brackets and reduced zero stroke results in dead stroke that is 35% shorter than band-type cylinders. Comes with stainless-steel seal band for long life and low leakage. Available with NPT ports.
Humphrey Products Co., (269) 381-5500, www.humphrey-products.com
