Engineered connectors
April 3, 2005
Engineered connectors feature one-piece construction (no brazing). Bar stock construction allows a full wrench pad, required for installation in tight spaces. High tensile strength and hardness allow for high-pressure holding capacity. The ...
Engineered connectors feature one-piece construction (no brazing). Bar stock construction allows a full wrench pad, required for installation in tight spaces. High tensile strength and hardness allow for high-pressure holding capacity. The connectors are used with hydraulic fluid, oil, air, refrigerant, water, chemicals, fuels, and gases. They are made of steel, brass, stainless, aluminum, or Monel and come in sizes 1/8 to 2 in.
Fluid Line Products Inc.,
(440) 946-9470,
www.fluidline.com
