Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 17836products01 00000009889
Axial-piston pumps
April 24, 2006
PVM open loop, axial-piston pumps are available with multiple controls. Three frame sizes offer maximum displacements from 0.66 to 7.94 in. 3 /rev, maximum pressure of 4250 psi, and speeds to 3600 rpm. Hardened steel shoes run on hardened ...
PVM open loop, axial-piston pumps are available with multiple controls. Three frame sizes offer maximum displacements from 0.66 to 7.94 in. 3 /rev, maximum pressure of 4250 psi, and speeds to 3600 rpm. Hardened steel shoes run on hardened swashblock surface for contamination resistance, high-pressure operation, and increased life cycle. Hydrodynamic bearing support withstands high temperatures for infinite bearing life.
The Oilgear Co., (414) 327-1700, www.oilgear.com
