Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product Newprod0301png 00000000346
Mini proximity sensors
April 3, 2005
Two lines of miniature inductive sensors target automation equipment with limited mounting space. The IT line are 6.5 mm in diameter and have smooth bodies that measure 30-mm long. The IE line are 8 mm in diameter with 30-mm threaded body ...
Two lines of miniature inductive sensors target automation equipment with limited mounting space. The IT line are 6.5 mm in diameter and have smooth bodies that measure 30-mm long. The IE line are 8 mm in diameter with 30-mm threaded body lengths. Both lines include sensors with 2-mm flush or 4-mm nonflush sensing ranges. The sensors are dc pnp, normally open, and have stainless-steel housings for higher tightening torque.
IFM Efector Inc.,
(800) 441-8246,
www.ifmefector.com
