Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9684spotlightfi 00000003470
Cutting rings
June 27, 2005
DiNova cutting ring is used for hydraulic DIN 2352/ISO 8434-1 fittings for no leaking, clean equipment, and safe working conditions. Ranges from 6 to 42 mm OD, series L and S. Enables easy assembly of hydraulic pipe circuits. Metal/metal sealing ...
DiNova cutting ring is used for hydraulic DIN 2352/ISO 8434-1 fittings for no leaking, clean equipment, and safe working conditions. Ranges from 6 to 42 mm OD, series L and S. Enables easy assembly of hydraulic pipe circuits. Metal/metal sealing reinforced by two PTFE seals and gripping safety. Seals won't go into compression position until crimping achieved. Compatible with 24° cone seal fittings.
Legris Inc., (480) 830-0216, www.legris.com
