Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 New Product 9695spotlightfi 00000003482
Tube fittings
June 27, 2005
Sealastic Fittings provide tight, leak-resistant connection on plastic and metal tubing, including copper, aluminum, Monel, thin-walled and stainless steel. For low and medium pressures to 1300 psi, with sizes from 1/4 to 1 in. OD. Flexible, ...
Sealastic Fittings provide tight, leak-resistant connection on plastic and metal tubing, including copper, aluminum, Monel, thin-walled and stainless steel. For low and medium pressures to 1300 psi, with sizes from 1/4 to 1 in. OD. Flexible, cushioned seal makes them ideal for applications where vibration, high speeds, and mechanical shock encountered. Quick and easy installation. No special tube preparation required.
Chicago Fittings Corp., (877) 638-9009, www.chicagofittings.com
