Hydraulicspneumatics Com Sites Hydraulicspneumatics com Files Uploads Custom Inline Archive Www hydraulicspneumatics com Content Site200 Ebooks 01 01 2006 45155 Fig10quizg 00000020697
Quiz on Chapter 10: Directional Control Valves
Feb. 10, 2007
1. A check valve is a/an: directional control valve counterbalance valve reducing valve 2. Pilot-operated check valves have ___________flow in one direction. increased controlled decreased 3. Pre-fill valves have ___________ flow at ...
  1. directional control valve
  2. counterbalance valve
  3. reducing valve
  1. increased
  2. controlled
  3. decreased
3. Pre-fill valves have ___________ flow at low pressure drop.
  1. higher
  2. less
  3. the same
4. Pre-fill valves are used to:
  1. make small cylinders move faster
  2. give large cylinders more force
  3. fill and empty large cylinders quickly
5. A plain check valve can be used as:
  1. pilot-operated relief valves
  2. direct-acting relief valves
  3. either type relief valve
6. A 2-way valve has:
  1. one working port
  2. two working ports
  3. three working ports
7. A 2-way valve can have:
  1. two positions
  2. three positions
  3. four positions
8. One 3-way valve can power a double acting cylinder in both directions.
  1. True
  2. False
9. A 4-way valve has:
  1. two working ports
  2. three working ports
  3. four working ports
10. A 5-way valve is normally used in:
  1. air circuits
  2. hydraulic circuits
  3. both air and hydraulic circuits
11. Direct solenoid-operated valves:
  1. are only DC current activated
  2. are only AC current activated
  3. operate off either AC or DC current
12. Solenoid pilot-operated valves must have at least___________pilot pressure minimum.
  1. 25 to 50 psi
  2. 50 to 75 psi
  3. 75 to 100 psi
13. The X port on a solenoid pilot-operated valve is for external___________.
  1. drain
  2. pilot pressure
  3. either drain or pilot pressure
14. The Y port on a solenoid pilot-operated valve is for external:
  1. drain
  2. pilot pressure
15. Stroke limiters on the working spool of a solenoid pilot-operated valve can:
  1. slow spool travel
  2. speed up spool travel
  3. control actuator speed
16. A D10-size valve can flow up to:
  1. 80 gpm
  2. 90 gpm
  3. 100 gpm
17. This symbol is for a:
  1. hydraulic solenoid pilot operator
  2. pneumatic solenoid pilot operator
  3. direct-acting operator
18. An open crossover (transition) valve blocks flow as it changes position.
  1. True
  2. False
19. Pneumatic directional control valves:
  1. are always subplate mounted
  2. are always in-line mounted
  3. may be subplate or in-line mounted
20. A series bar manifold can have as many as:
  1. one station
  2. two stations
  3. three stations
