One-piece V-cup seal
April 3, 2005
Redesigned one-piece V-cup seals provide long seal life, as well as less manufacturing and assembly. Used in outboard motor fuel assemblies, the seals are made of a special, fuel-resistant fluoroelastomer material that can withstand the harshness ...
Redesigned one-piece V-cup seals provide long seal life, as well as less manufacturing and assembly. Used in outboard motor fuel assemblies, the seals are made of a special, fuel-resistant fluoroelastomer material that can withstand the harshness of extended fuels. The material also provides good flex fatigue resistance and compression set.
Minnesota Rubber,
(952) 927-1400,
www.mnrubber.com
