RL series cylinders have an anodized aluminum housing and precision ground tool steel locking mechanism and are rated for four million actuations.
RL series cylinders have an anodized aluminum housing and precision ground tool steel locking mechanism and are rated for four million actuations. They offer a 200 msec response time, low backlash, and zero rod movement on actuation. Compressed air opens the rod lock; when air is exhausted, spring force actuates a mechanism to unlock the unit. A 3-way air valve controls the rod lock unit.
The great advantage telescopic cylinders have over any other type of cylinders is their ability to provide an exceptionally long stroke from a compact initial package. The collapsed...
Rodless cylinders are used primarily for their compact design—they provide the same stroke of conventional cylinders, but in roughly half the space. But they hold other advantages...
