Cutting seal friction saves energy and helps eliminate undesirable stick-slip motion.
Operators of fluid-power systems increasingly demand friction-optimized piston and rod seals for hydraulic cylinders. Excessive friction not only wastes energy, it can also accelerate wear and lead to premature seal failure. But too little friction and a seal leaks. Getting the balance just right across varying pressures and operating conditions has been an ongoing challenge for seal manufacturers.
Parker Hannifin’s Seal Group has developed a product that meets this goal. The company’s new Ultrathan HL rod seal features a series of cascading, pressure-activated sealing lips that, according to Parker officials, reduce static and dynamic friction in hydraulic cylinders.
Compared with conventional U-rings, the HL single-acting rod seals reportedly reduce friction-related losses by 30 to 70%, depending on load, without compromising sealing capability. This increases hydraulic-system efficiency and can lead to significant energy savings.
Stepped pressure activation
Various parameters influence friction in hydraulic seals. The size of the contact area between the seal and respective sliding surface is one key factor. In essence, the larger the contact area, the higher the static and dynamic friction.
Also, hydraulic-system pressure dictates the amount of friction required to prevent fluid from leaking past the seal. For example, friction at lower system pressures, or in differential cylinders with small pressure differences, is significantly more critical than in cylinders operating at higher pressures. With conventional U-seals, a large portion of the dynamic sealing area typically contacts the piston-rod surface even at low system pressures, which increases friction. The HL takes a different approach.
The HL seal profile features three individual sealing lips that consecutively contact the mating surface as pressure rises. In low pressure or pressureless conditions only one lip contacts the rod. The resulting small contact area produces significantly less friction, compared with standard U-cups. And less friction means the seal generates less heat, permitting higher travel speeds. In addition, because only the primary sealing lip engages at low pressures, the HL minimizes breakaway friction typical after prolonged down time.
As system pressure rises, the seal’s cross section deforms slightly and additional sealing lips are activated. Thus, sealing capabilities increase with pressure and the number of sealing edges in contact with the rod.
Multiple sealing lips also reduce the amount of oil on the rod surface that seeps past the seal as the cylinder strokes, further reducing leakage. Although dynamic friction slightly increases as more lips engage and the contact area enlarges, overall, it remains at a low level. In addition, the design virtually eliminates the risk of stick-slip at slow travel speeds.
